Probably not the venturi and jet sizes are probably different and the engine would be running too lean. It will cook the pistons and score the cylinders ? It is possible the 150 is just a detuned 175 you will need to see if it has the same powerhead and exhaust tube (inner) if it is the same engine then you will be lowering your HP accordingly.
Yes, just a detuned 200 (both the 150 and 175 in this case).
The venturi on both carbs is the same - 1.312
The WMH2 has a .064 main jet, the 7, .062
The 2 has a .044 progression (off-idle) jet, the 7, .034
The 2 has a .044 idle air jet, the 7 has a .040
and the 2's backdraft jet is .080 - the 7 has NO backdraft jet
(the backdraft jet, also called a bowl vent improves fuel economy at mid-throttle by reducing the air pressure in the bowl - so fuel is not "pushed" up the venturi. With this jet the motor may still function fine even though it was never included on your original carbs (or you could simply plug it - ???? never tried that)- obviously, the engineers feel it wasn't needed on certain carb models WMH 4, 6, 7, 8 and 10 to name a few)
You should be able to swap the jets (if serviceable) from your existing carbs to the (new) carbs.
If the price is right, I would certainly give it a try if your current carbs are toast..
Depends on serial number.....It is possible the 150 is just a detuned 175
Nope as the 200 is 2.4 liter and the 150/175 are 2 liters. Depending on serial number the earlier 175s had a bigger exhaust chest and the exhaust on bottom of block is 2 large "D" shaped exhaust ports(gasket 27-75909). If its the later model it is the same block with with exhaust ports raised .080 to give it a little more umph on top end.....Yes, just a detuned 200 (both the 150 and 175 in this case).
The venturi size is the same , the differences is the metering orifices cast into the carb and the main discharge tubes, that why different jet sizes...and the WH2 carbs will not work on your motor without a lot of trial and error in jetting.The venturi on both carbs is the same - 1.312 The WMH2 has a .064 main jet, the 7, .062
The reed cages are the same on the 150/175 as they are 10 pedal vertical reed motors and the 200 is a 14 pedal horizontal reed motor. The intake and reeds off a 200 will not fit a vertical reed motor and to make it bolt up you would have to mismatch the front crankcase halves as they are the difference..I had a good look at the 200 - it has a different reed cage - the 150/175 share the same cage - so that alone would be about a 200 dollar "upgrade" on top of the cost for jets, gaskets etc.
Swap main jets, idles should be find due to smaller idle tubes...Should I try the 2's the way they are or swap the jets?
Doubt you get better mileage as the backdraft circuit only works in the mid range RPM (2500-3500rpm) timing will stay the same which is 18° BTDC or 20° at cranking speed as a 150 of the same year is 16° and 18° at cranking and make sure idle stablizer if still equipped are disconnected (removed is my choice)Might I get better Milage backdraft jet. Right now I suck gas like crazy. Would the timming be the same?
