Chrysler 55hp issues
I looked into it and it doesn't match my issues since now I can idle it but for some reason its burning my bottom spark plug after a few minutes at full throttle.
I have replaced the points but I did go ahead and re check them. All good and gapped properly. When its running im not noticing and blowing out of the carb I did cover the carb opening with my hand and it shot gas at my hand. About to scope the reeds and pull if needed.
Just finished swapping the carb out and redoing every adjustment to carb and tower and she's been running very well the last hour in a tub pulled the bottom plug and there wasn't much fuel on it but not burnt at all. I did see some damaged fuel line so I changed it out. Fingers crossed It does good when I test it tomorrow.
Next time: pull the plug wires and put them back on so's it can be pulled away easily start and pull each wire and see if it makes any difference in the way it runs???
Guess it's a Force. Sorry. Some parts may work.
Sorry for the delays been busy. Got to take it out today and ran for about 2 hours no issue. So far it seems like I had my timing too far advanced and probably leaned out too much. Thank yall so much for the help on getting this old engine back going.
