Jupiter Dinghy
I took the 1979 Evinrude 9.9hp with a new water pump/impeller out for a spin today and I noticed something strange: The cooling water coming out of the exhaust hole underneath the power head at the back, was coming out nicely (very hot but a wide and thick spray as it is supposed to be) and as soon as I was opening the throttle wide to get on plane, the water stream would stop. I roll the throttle back and the water starts spraying again as it should.
If I had not just replaced the water pump, I would think it might be a pump or impeller issue, but here is what I found out when I got home and hooked up the ears to flush the motor: You will see on the pics below the black arrows pointing out where the water is coming out.
Weak at low RPM (first pic) and getting much stronger when revving up the motor (second pic), which would explain why the water stopped coming out of the exhaust hole at high RPM as it is "diverted" through this area of the mid section, instead of following its route through the power head.
Anyone has seen / encountered this before? And any suggestion as to what needs to be done to fix this?
