Dipstick tube replacement
dlyle
"Good Day,
I'm dealing wi
"Good Day,
I'm dealing with a 1991 5.7 350 mag Mercruiser Alpha 1.
My situation:
The dipstick has broken and about one foot still remains in the tube. I feel certin of this because the tube can be used to suction out the oil. So I figure it's not in the bottom of the pan. I was going to remove the tube and retrive the broken piece but I can't remove the tube without removing the exhaust manifold (big job).
My thinking: I'll cut the tube and remove it in sections if necessary (hopefully the broken piece won't fall as I pull more of the tube out).
Assuming I'm successful and I retrieve the broken piece....
My question: Can I retrofit a different tube, maybe one that would extend out next to the exhaust manifold and if so does anyone have any suggestion for a particular make or model? Additionally, could I fabricate (bend) the correct replacement model and make it work in this manner? If I get the old one out I'll never get a new one installed in the original configuration without removing the manifold (still a big job).
I'm hoping someone has done this before or has a better solution.
Thanks for your time and regards,
David Lyle"
"If you can get a small rare e
"If you can get a small rare earth magnet and attach it firmly to a speedo cable or something similar, you could feed that through a plastic sleeve into the dipstick tube and possibly grab the piece that's still in there.
How did the stick break off? I have removed exhaust manifolds and while it's a PITA due to the weight, I didn't really consider it a big job."
"Thanks Jim,
I have looked fo
"Thanks Jim,
I have looked for one of those flexable magnets all winter and spring and can't find one that will fit inside the actual tube itself. I was thinking about attaching a magnet to the plastic suction tube I use when suctioning the oil out but with TWO bends in the tube I'm afraid I'd wind up with something else stuck in the tube. I really don't want to have to remove the manifolds if I can help it, not that I can't do it it just seems like an excessive amount of work if I can find an alternate method thus the reason I'm seeking suggestions from the experts here.
The old broken stick is the flat type (not solid round) and there are several "pot" marks on the stick. Nothing serious but the type you would see where a small bit of rust may have formed, then the rust broke away. You know, after sanding away a rust spot it leaves a small "pot" mark. Anyway it appears this was the weak spot and from all the stressing and bending, I guess it had all it could stand. The replacement stick I have is round and will flex much better.
I really would like to reroute the dipstick to another location which would make it easier to access. The way it is now and being in front of the engine makes it difficult to get to since that's right behind the passenger bench seat.
David"
"David, I am not sure that you
"David, I am not sure that you will be able to remove the dipstick tube, without pulling the oil pan. I had my GM 4.3LX out of the boat last summer to replace the pan, and it seemed to me that the dipstick tube had some curves to it, and went through a hole in the oil pan gasket surface. In addition, will the broken piece of the stick stay in the tube, when you pull it out? Remember that the dipstick tube is right on the bottom of the pan, allowing you to pump out all the oil for a oil change. This means that the dipstick shouldn't fall into the pan, as long as the tube is in place.
I recommend that you do some research on the shape of the tube and see if it may be possible to remove it. It might be real obvious that you won't be able."
I am looking for a 1991 454 mercruiser dipstick tube and dipstick. Goes in a 1991 cobalt 22ft ski boat. Or something that will replace that dipstick tube
Use the link up at the top of this page - Boat Engine Parts - click it and select Mercruiser. Enter your serial number and scroll down to the appropriate breakdown (the one showing the oil pan, typically)and go from there
In your situation, I would think about carefully cutting off the top of the tube with a mini tubing cutter, the kind with a rolling cutter wheel like this.
You can get one for less than $5 at JEGS. You could also use snips or a hack saw, but it would not be pretty.
Cut the tube off below the top end of the remaining dipstick, so you can just pull that piece out. Then take the other piece you have with the handle on it, and shorten it so it will be a new "shortie" dip stick to use in the remaining tube. You'll need to etch new full and low lines on it, based on the oil you have in it now which hopefully is full enough to be the new full.
A possible downside is oil might come out of the short tube when running, just from splashing up the tube. I doubt it, but don't know for sure. If that were the case, you might be able to seal the dipstick cap with an O-ring, duct tape, bubble gum or something.
Forgot Don S`s quote about doing it right the first time
but remove the manifold .Not a bad job if you remove the elbow first and then the manifold. Get 2 long bolts, longer than the manifold bolts ,cut/grind the heads off to use as guides.
If the broken tube is at the block you can use a tap of the proper size to screw in and remove the remaining tube, then install the new one
In your situation, I would think about carefully cutting off the top of the tube with a mini tubing cutter, the kind with a rolling cutter wheel like this.View attachment 34313
Mercruiser marine dip sticks are different then Automotive.
The tube goes almost all the way to the oil pan surface. The dipstic tube has a threaded fitting at the top to screw on a hand pump (garden hose threads) to suck out the oil. Many if not most boats do not allow easy or have no access to the oil pan drain plug.
Automotive dip sticks dont go deep enough.
Also if you look at the link i posted, the dipstick tube is shaped so the pull is at the front od the engine for easy access.
Disregard the link in my earlier post It was for the original post for a 350 engine.
Always start your own NEW post
your engine has two choices 1991 454
Cast oil pan link (note: most parts are NLA but a google search may find them for sale)
Stamped oil pan (note: most parts are NLA but a google search may find them for sale)
Shoot. I was trying to solve the problem from 2006. Sorry everybody.
Ayuh,..... I agree with BD, pull the manifold, then you can pull the dipstick outa the block, by hand,....
No reason to be cutting it into bits,....
You would still need the manifold removed in order to install the new tube.
You're making more of a job for yourself by not removing the manifold. Its 8 bolts and 4 hose clamps and your working like a gentleman
