Sailorchlud
I have a 2002 j115pxsnf with a trim /tilt intermittant failure. Down trim works every time on the down button on the the motor switch and on the throttle switch. Up trim works only intermittantly when either up switch is activated. I have no apparent corrosion on the wiring, and all wiring connections seem solid. If I unscrew and jiggle the relay bracket I can get it to work for a bit, then it stops working after 3-4 activations.
I had suspected vibration from the motor running was working a wire connection loose, but I cannot find any weak connections.. and it stops working after a few tries even without the motor running while in the driveway.
Should I replace the up relay?
