theydrewa31
Hello All,
Trying to get this outdrive put back together after replacing bearings, O-rings and gaskets. I have one bearing left to install and have some questions. I am including a diagram below to clarify the bearing I am trying to install, the bearing is circled in RED.
OMC calls for special tools to install this part, which ensures that the bearing is installed to the correct depth in the lower gear housing. The setup for the special tools are shown in the photo below.
The way it works is that the bearing is installed on the end of the tool assembly, then tapped into place with a soft mallet. The bearing will be seated to the correct height when the plate (labeled as part no. 391260 in the above photo) makes contact with the top of the lower gear housing as shown in the photo labeled "84" in the above image.
I think that on older models there was a lip on the bottom of that cavity that the bearing would bottom out on but that is not the case for my model. If it goes in too far it will simply fall out the bottom into the dog clutch area. I have no hesitation about buying any special tools needed, but some of these tools are impossible to find.
My questions for anyone out there who has done this or knows anything about this bearing:
I am including additional information below, although it probably isn't necessary:
- How crucial is the depth for this bearing? I did notice that there seems to be close to 1/4" of extra space on the bearing shoulder of the drive shaft when the bearing is seated onto the drive shaft. If I get it "close" and within the shoulder range of the drive shaft is that good enough? I feel like that's a bad idea, but I'm searching for a solution since the tools are so hard to find.
- Is there any other way to install this thing without the special tools? I have bearing/seal drivers, and I could tap it in with one of those, but again there is nothing to stop it on the bottom, and I don't want to install it to the wrong depth and have problems further down the road.
- If anyone out there has the tools, do you want to rent them to me?
- This is a 4.3L OMC cobra, the lower unit is a 1993.
- The part numbers for the tools OMC lists for the job are below:
- Spacer - 326584
- centering plate - 391260
- Rod - 326582
- Driver - 326574
- special washer - 326587
