DV8 SME Charging Problem
G' day Simon,
Are you measuring voltage at alternator or at end of wiring run at dash board?What are you using to record voltage analoge gauge or a digital multimeter,does the system have a field switch fitted if so remove & retest.
Cheers, Shakey.
Hi slight change of tack. Has anyone had to replace there voltage regulator/rectifier on a dv 10 mine has burnt out. Bukh no longer make the part the closest I can find is from a ragerini engine. Does anyone have any experience of getting over this problem?
if you have an auto electric shop near by, I'd pay them a visit with your old alternator...many times, they can repair it or, worst case, find you a suitable replacement.
