rockfisher805
I recently rebuilt the car it looks perfect so when I go to start it will start but it will only run for like 5 seconds and then it dies has a new fuel pump new plugs it had died on me when I was out in the ocean after running it for a few miles its starting to slow a full throttle and then it died it also has a new water impeller and thermostat I don't know what else to check that might be causing this problem I would really appreciate some help thanks in advance the compression of both cylinders is about 65psi
