remove the hose from the bottom to drain it first, loosen the clamps from the riser and remove riser, for the manifold remove the 2 outer bolts and1 inner one have a helper hold it while you remove the last bolt, lift and remove.
To install, notch the 2 end holes of the manifold gasket so that they fit over the bolts if not already notched. hang manifold by 1 inner bolt to hold it in place.
Install 2 end bolts and remove inner bolt.
slip gasket between manifold and head, install 2 inner bolts, tighten all bolts,
Use Permatex Aviation sealant on the manifold, and riser gasket, install riser tighten bolts and clamps.
