My '81 Evinrude 100993s has good plugs/wires/coils/fuel, and runs strong with start lever at half, though rpm is a bit low with lever all the way down. Issue is stalling when put into gear, either forward or reverse. The throttle stop screw is nearly all the way in, yet touches nothing within full range of movement. There is a little play in the linkages, but not much, seems relatively tight. Motor seems to just die when engaging into gear.
