Hi
I have searched the forum without finding help regarding this specific model so I post the question here.
Im pretty sure my motor is a derated 25 hp meant for the european market (I live in Sweden). Its a rope start with ordinary choke (no primer, a throttle/plate that closes the air intake)
The problem is when starting it cold. It fires on the third pull at the latest but it wont idle, it dies after a few seconds. I have to quickly put in gear to be able to give it more gas, and that solves it, but Im not satisfied with that because its not always convenent to be forced to leave the bridge immediatly after start. My starting sequence is as below:
1. Pumping the fuel bulb until "hard" (I see fuel leaving the fuel filter through transparent fuel hose).
2. Apply full choke
3. Turn gas as much as possible (i guess its start mode, the markings are all gone)
4. Pull rope
After failed start I have tried both full, half and no choke, full choke seems to give the best result but it still dies after a few seconds.
What I have done when troubleshooting:
1. Adjusting the low speed fuel-air mix needle starting from 1 turn from the leanest up to 3 turns from leanest (least fuel) with no effect on starting. When hot, I have found the best setting to be 1 turn from leanest mix.
2. Checked the choke throttle - works fine - when pulling the choke out the throttle closes the intake completely.
If I quickly put in a gear, I only need to rev it slightly above the neutral gashandle limit in order to get it running. It wont take long before I can go back to neutral and the engine runs fine on start gas position and soon on idle aswell.
I bought it a few months ago, the seller said he cleaned the carb and changed fuel filter. Considering the smooth run when warm, Im not so sure its a fuel issue.
Any help would be much appreciated.
Thanks, Carl
2. Apply full choke
4. Pull rope
Thanks, Carl
