I have a 1985 Evinrude 30hp outboard (E30ELCOA). New to me! I have rebuilt carb with OEM rebuild kit. At WOT the motor sounds limited and I can only get just above a crawl. I have also noticed a fuel/oil foam forming in the throat of carb when running WOT. The motor will idle in gear and neutral) without issue.
I have replace plugs with OEM Champs
Rebuilt carb
Replaced fuel lines
New gas tank (6 gallon Portable) with main fuel line leading to motor
Question is:
Could the nozzle gasket in fuel bowl be leaking and allowing too much air to mix and foam fuel?
Could the carb simply be out of tune?
Could fuel pump cause this?
What else could cause this?
Rebuilt carb
Replaced fuel lines
Question is:
