Hydraulicphoto
Hi,I'm stuck on a fantastic holiday weekend with no boat! I suddenly got a lube gear alarm on my 2010 5.0 MPI Mercruiser sterndrive on my 22' Sea Ray Sundeck. I had checked it before leaving the lift. I opened the cover to find the reservoir empty, I topped up the reservoir and got home to find no oil left in it and oil in the water around the stern drive, nothing in the bilge. I lifted her and traced the dripping oil leak. Looking at the drive from the stern I found a black hose had come undone from a nipple that appeared to be part of the transom collar mounting on the starboard side. I want off to West Marine got a new SS clip and tried to reconnect the hose. The nipple was very difficult to get to, set right back into the transom through fitting. I soon realized the the nipple use to be much longer and had snapped leaving only about 1/2 and inch left on the casting. The rest is broken inside the rubber hose. I have panicked a bit because it looks as though the whole cast through hull mount will have to be replaced because of a tiny nipple???????? Any advice would be appreciated.
