Brian silk
You can call me at 604-312-9566. Or email [email protected]
Hello. It sounds like the flame sensor has gone. It thinks it is hot so it runs in coodown until shut down. It can be tested by jumping the two contacts on the sensor. If the heater turns on in start mode now, slow fan, glow plug, and then fuel pump then that is the problem. This only works with model 25 1640, not 25 1738. The switch is still available, about $70. Off the top of my head.
I'm not sure what you mean by it would not go I to coodown. Would it not shut off at all and you had to pull the fuse?
I have the digitroller, the wiring came out of the box ready made, i only had to connetc it to the heaterGood. Get a CO detector anyways.Do you have a digitroller?
it is the salon. I think the unti does use the thermostat. It goes full power until it reaches the set temp, then slows down. But still quite some heat comes.Is the thermostat. Mounted in the salon?
the cold air comes from the cockip locker where i installed the unit. I can also use a 2 feet ducting and suck in fresh air. Noise is worse with the ducting but its there without ducting, too. I will try to find someone with a same unit and compera the sound.Is the cold air supply to the heater ducted to the cabin or does it just pull from the heater compartment? Some of the fans have a kind of ticking sound that really carries through the intake ducting.. If this is the case you can order 75mm cold air intake muffler. They work fantastic. But bearing sound, grinding or squealing is not normal for a new heater, obviously.
Sorry. For he delay.. Turn the thermostat off and remove the left hand side cover. Slot on the bottom..put a key in it and twist, it will pop off. Put a jumper between term. 4 and 6 and turn on the thermostat. This will unlock the heater if you tried 5 times to start it. It locks up. From that.
I checked with Espar and they confirmed. The digitroler will not work withheld d3l 25 1738. You need the 567 00 97 thermostat 12v. You will have to look at the wiring schematic and match the colour of the wires on the heater side of the thermostat plug with the terminals on the thermostat. Send me an email and I can scan simple schematic and send it to you. [email protected]. Again, to others,all other questions please post on the forum, I don't want my email replacing the forum.
I tested my D7L as you [Brian] have suggested and the findings are very interesting... the fuel pump does not make a clicking noise at any time after the blower starts up. So, I pulled the control wires off the fuel pump, and tried to test to see if there was any input voltage by connecting them to a volt meter (see quicktime movie 1). There was *no* voltage measured in the fuel pump wires. I also put a magnet over the impulse generator, but this still did not generate a voltage to the fuel pump, or cause the pump to make a clicking noise.
Response from Brian Silk:
Did you tap the motor shafts while the heater is in start cycle like I mentioned? You could also open the large control box and see if all three relays are closed. If the third one is not, press the end of it to close it and see if the pulse starts.
