edorminey12
I have a BF 50 A Honda outboard that is giving a beeping sound just as soon as it is put in gear. There is no beeping at idle.
The beeping is one second on and then one second off and continues as long as the motor is in gear.
I have disconnected the temperature and oil sensors and nothing changes.
I disconnected the tilt/trim at the first plug from the tilt/trim unit. I was thinking about unplugging it on the side of the engine if I can figure out where it connects.
The motor runs fine and will not cut back any. The oil light is green continuously.
I don't really need the Tilt/Trim at all if that is what is causing the problem but other than what I've done, I don't know how to disable it.
Any ideas?
Any ideas?
