Honda BF135a Overheating if we go over 4k RPM
Murph68
I’ve been reading that there is a grommet that can be replaced in the mid section? Can someone show me where it is please and do you have to remove the mid section to replace it? Attached is a pic of mine.
Have you replaced the water pump recently with a new impeller etc? Is the outboard pumping lots of water through the telltale?
Hi,
No picture attachment came through so you may want to try again.
I'm guessing the grommet you're being told about could be one of two grommets used to seal both the upper and the lower end of the water tube (item 7 in link below) that directs water from the pump into the engine block.
The lower tube grommet....at the water pump outlet....is item 12
The upper tube grommet is also item 12 in link below:
Either of those grommets can be knocked loose or damaged when the water tube is moved. As you can see in the last link, Honda made an effort to secure the tube and upper grommet with a plate clamp (13) and a bolt (36).
HTHY
Good luck.
Hi I have checked water pump and housing both brand new. She’s pumping water but looks a bit weak. I’ve changed both thermostats, 3 water sensors and the popppet valve. Cheers
Hi,
HTHY
Good luck.
Tgsnks for that. Do you have to remove the mid section to change them? I’m guessing yes and is there anything I need to be weary of if I remove it? Cheers
I've never worked on a 135 so I can't provide specific instructions on how to do things like remove the extension case.
I See there's a third water tube seal listed (item #8 in the first link I provided above. I can't even tell you how seal 8, grommet 12, and the water tube are fitted. I assume the three work in conjunction with each other.
When you looked at the pump, did you take note of how that tube engaged the pump outlet? Without a picture or diagram I'm just guessing.
I believe, with the proper tools, you can replace that upper grommet with the extension case in place.
The longer the extension case though, the more difficult it will be.
Sorry, but you're probably going to need to pull the lowwr unit off again to examine how the tube is fitted and determine if you might be losing water there.
