"Inherited a 1990's 15 hp
"Inherited a 1990's 15 hp Honda outboard and 14' boat with instructions to take the kids fishing. Fist time out motor started immediately ran great unfortunately with in 5 minutes or so I noticed no tell tale water spray. Shut motor down, rowed back. Motor very hot. Installed new water impeller, sprays great. My problem is that motor purres like a kitten when hooked up to garden hose but will not run well when motor is in water unless cowling is removed. Back home ran motor with shaft in garbage can full of water same problem, runs great without cowling, hardly at all with cowling. Noticed that when ran with shaft submerged water appears in bottom of engine case and runs out drain hole, but exhaust gas is bubbling in this water. This does not happen when using garden hose attachement for cooling water. I assume that exhaust leak is fowling the air under cowling causing motor to run poorly. My question how difficult is it to fix? I cannot see the leak but it appears to be near where the exhaust exits the motor case heading down the shaft. Do I need to attack from the bottom or top? Is there a manifold and and exhaust tube? Is this a job for the shop? Also does anyone know what the initial mixture screw setting on the carb should be? Any help would be appreciated, the fish are in the river!"
