My Honda BF15A will not tilt down on its own. After moving the tilt lever to the run position, the engine will not go down after slightly tilting up as normal.
If I reach behind the engine to an arm in the tilt assembly and manually move it, the engine tilt will release and it will move down to the 30 degree position and stop and go no further. If I jiggle or bounce the engine up and down slightly, it will eventually tilt all the way down.
Tilting up does not seem to be an issue, although it does not seem to stop at the 30 or 45 degree settings.
Any ideas at what to look at? I'm thinking a spring that moves one of the tilt support arms.
