2004 Honda 225, if cruising around 4,500 RPMs, after a few minutes the engine stalls. Red over heat light comes on, sounds once. Turn key off, restart and can immediately cruse at 3,900 RPMs for the rest of the day.
High and low Pressure filters are new, no change.
I've seen some similar threads on this, and most do not say what fixed their issue.
I've seen suggestions on VST, HP pump, water return tubes on exhaust manifold, IAB intake air bypass solenoid, clogged fuel injectors. Without throwing parts at it, has someone had this issue with a known fix?
