Hi, I have been looking through this forum and it has helped alot. Thx.
I have a Honda bf40A from 2007 it only runs on 2/3 cylinders, i have cleaned the carbs but with no luck, if I spray som carb cleaner The third cylinder fires right up, so I am fairly certain I have a fuel issue, the slow jet is clean, and open. The o-Ring on the slow jet is a bit wir now, Could this little o-Ring aus my problem? Even if I give it more throttle so it should go over on Main jet it wont fire.
IT all started when Testing if it ran good for the season, it only ran on 1 cylinder 2 and 3 were dead. Remowe all carbs and cleaned after that it ran on 2/3 but still not fiering on 3 bortom cylinder. I dubble checked again that the slow jet Was open and not clogged and also the small holes inside avefything is open, but see3m it still gets no fuel. Hope someone has some sort on idea on this.
