"Let me start off by saying th
"Let me start off by saying that I am not the mechanic in the family, but the one that wants to search online for an answer.
I took some pictures, which you can view by clicking the links below, of the problem in question and a few random pictures. You may notice that the prop and the carburetor are missing, but the prop is being rebuilt and the carburetor is being cleaned.
We just recently bought this 1990 Kayot knowing that it had been 2-3 years since it has been in the lake, but worked before that time. To test the engine, we put some ears around the engine before turning the engine over. When we turned the water on, a screw popped out of the engine. There are threads on the screw, but not in the opening that it popped out of.
We do not know if it is necessary to have a screw in this opening or if their was a nut that fell down when screw popped out. I would hope that OMC would not design a motor so that any num-nuts, like us, could unscrew something, only to have the nut fall into the engine.
The only fluid coming from the opening is water. From the first link, you can also see that there is some corrosion around this opening. Is it some sort of pee hole?
If you need anymore pictures, let me know. Thanks for any help that you can give me.
http://img375.imageshack.us/img375/9217/19352830zr0.jpg"
http://img75.imageshack.us/img75/4447/img0280oh4.jpg"
http://img375.imageshack.us/img375/8620/img0281dt9.jpg"
http://img75.imageshack.us/img75/4357/img0282yv5.jpg"
http://img75.imageshack.us/img75/7417/img0284ax4.jpg""
