The IAB valves are completely functional. I have had it apart several times . The only thing that I haven’t replaced is the IAB solenoid, but I tested it . When I connect it to the 2pin connector you cannot hear it click. When I put 12 volts to directly it sounds fine , and it checks to the manual as far as ohms reading. This is the part that I think is the problem. I DO NOT have continuity to ground from the #9 pin on the ECU. By the manual it says I should. If not replace ECU. Thoughts?Hi Gary, I don't believe your IAB has anything to do with the lack of RPM. Your IAB should Close (activate) at idle in order to direct airflow via a longer intake tract to stabilize idle airflow. Prior to start up, valve flap is fully open. At aprox 30% thottle, flap starts opening shortening intake tract thereby accelerating air flow into the intake manifolds to increase volumetric efficiency improving both power and economy. What you think is opening at start up is actually closing the shorter tract. So I suggest you check fuel pressure , compression, and spark under full throttle. I have seen the IAB valves completely siezed in half open, open and closed with the owner not reporting any noticeable performance issues.Hope this helps
