IAC Valve
Kirdud
Good day, captains!
It seems that the IAC valve on my Volvo Penta 4.3 OSI-E might need replacing.
After cruising for a while, when I shift into neutral, the engine sometimes stalls. On other occasions, when starting the engine the following day, it struggles to start and only runs properly if I give it some throttle.
My mechanic strongly recommends replacing it with an original Volvo Penta part. However, to be honest, the OEM part is quite expensive, and I've noticed that there are several aftermarket alternatives available.
Has anyone here had any experience using aftermarket IAC valves? Are they reliable, or is it really worth paying extra for the original part?
I'd appreciate hearing about your experiences and recommendations.
Thanks in advance!
Have you tried cleaning the IAC and the bore?
Don't know if it uses a IAC muffler
Many have used aftermarket like Sierra with good results but there are also a few that didn't work. The 4.3 is a GM motor
VP 343750, Sierra 18-7705, Merc 8M0220728
No, I haven't tried cleaning it yet. Do you think that might help? WD40 or carb cleaner? I'll try cleaning it first. Thank you for the numbers!
Comment about Rockauto
Car had a fault that said it was the vacuum valve for the gas tank. Bought AC Delco part from Rockauto and installed. Same problem so went thru testing again and came up with same part. Drop car off at Dealer and they replaced same part and it was fixed.
Yesterday, I tried to remove the IAC valve to clean it, but the screws are covered with the red paint that Volvo applies to all its engines, and I couldn't get them to turn.
I'm worried about damaging the screw heads, as I don't want to create further problems when trying to remove them.
Does anyone have any tips on how to deal with this? Is there a particular tool or technique you would recommend? Thanks!
