Clydemantwo
I have a 19' Bayliner with a AQ125 4 cyl. that I bought with a ignition problem. The ignition coil was replaced along with the points and condenser by the previous owner, because they were "used up", he was a blank!. First trip to the lake(I live in AZ) every thing was great but on the top end after about 5 minutes we started losing the plane, seemed like the motor got weak, no skipping, wheezing or anything just like it got weak. Slowed the throttle and it seemed better for a few minuets then stalled, again, no missing. Restarted in two cranks, good to only to repeat. Pulled the cover and felt the coil, way to hot to even get close to,water temp gauge was ok, no excessive engine heat.Points gapped correctly, but I didn't check it for spark. The accelrator pump showed fuel squirting so that was out. Hard to start so I let it sit for a few minutes and it started right up. Nursed it back to shore at a fast idle, almost a hour, with the engine cover off, it only stalled once but started again in a few minutes . I belive the coil is overheating because of incorrect wiring(ballested or ?, wrong ohm coil for 4 cyl?) I need to know what the correct ohms for the OEM coil are so i can check this generic coil or replace it. Is the ballast resister inline or should there be one mounted somewhere. I have a Seloc manual but the wiring and info is very poor. Is there a wiring diagram with this info anywhere? I bought it cheap so I new it would be a challange. If I missed a thread with this info could someone direct me to it.
It's gettin hot here in AZ, gotta get back to the Lake soon!
Thanks, Clydeman
Thanks, Clydeman
