wot only gets to 4400 rpms and so cleaned fuel system...ie tank, hoses, filter and carbs. no change. then it would drop to 2300 rpm out of the blue at WOT and come back intermittently. and also run rough at idle. would reach 5000 in neutral WOT. Tach started going in and out. checked spark and had no spark on 1 and 3 and weak spark on 2. no. 4 stayed strong through all. moved coils around and problem did not follow. Regulator was putting out 12.6 v at idle and went up to 16 v as throttle increased. Changed reg, and CDI with one off a spare motor same problem but now won't start at all. could it be puls coils or charge coils?
