J70plssd 2000 Johnson issues
Ashfurd7
Motor bogs down unload load then when going slow to dock it will stall but starts right back up. Has perfect compression spark on all cylinders. Things I’ve done…
New gas lines twice
Siphon valve
Drained tank
Cleaned carbs twice
New vro pump
New water pump impeller
New coil packs and wires
Exhaust gasket new
After doing the coil packs it ran great 7 times I took it out this year dumped thousands into it now doing the same thing!!! Help! Hopefully the last shot I think I have is a stator I ordered it! It tested faulty! Anyone have any suggestions. Also magnets under fly wheel have not shifted thanks you
