After doing a lot of reading regarding the Joe Reeves method I have a question regarding idle timing. From what I can gather, this method sets the WOT timing using a timing light. If this is set correctly will the idle timing be very close to where it should be? If the throttle valves are closed and the roller is set on the cam correctly, am I right to assume that the idle will be very close to being correct? :rolleyes:
