There was no "Standard" prop. but the motor was shipped from the factory with a 17" aluminum 3-blade. It was the dealer's responsibility to swap it for the best prop for the boat the motor was to be used on, and he could return the 17" for credit if necessary. Having said all that, we found that the 17" was good for the average boat/load, which your boat would fit into the "average" catagory.
Consider springing for the extra bucks for a stainless steel prop if you will be boating in skinny water where you will be touching bottom. It will pay for itself in the long run because it is so much stronger than the aluminum prop which will quickly self destruct.
Best bottom line advice: If at all possible, buy from a dealer that will allow "try before you buy".
