I agree, the timing does not go out of adjustment, but I don't know the history of this engine and have no way of knowing if anybody monkeyed with the timing as if have no idea what it's supposed to be. My compression numbers are 110,100,105,105. Ive had a problem with ignition modules dying on one the port side. I took it out yesterday , throttled up , it stumbled, then took off. Was at 40 mph and could have given it more but didnt. Ran about a mile, then back. Shut it down and had a hard time getting it to start. It did start, but had to limp back to the ramp. At home I discovered ignition box number 3 was doa. I have cleaned and rebuilt carbs, new water pump, ran resistance and DVA tests on every ignition component. All within spec. After module 3 died, I have spent the day swapping stator, timer base and last spare module from my parts motor. It sounded better and is running on all four cylinders. I have also cleaned tank and filled with fresh fuel. Module 1 died before I discovered I had 8 volts on the kill switch wire. Ive since replaced the switch. I did notice I would see about .0012 volts on the kill circuit. For good measure, I bypassed the kill wiring and ran it to the control box side of the red connector. I will work my way thru getting rid of the stumble. I might have to disassemble the carbs again, but working thru everything, I still do not know what wide open spark advance should be. I haven't messed with,it, but I don't know if someone has previously played with it. Sorry for the really long winded reply, but wanted you to know where I stood.
