A friend called to ask about their boat, which made a strange sound after running for about ten minutes, so they went back to the slip. I went out with them yesterday and noticed it not long after we left- it started easily, never stalled and every time it was started during that trip, it fired right up.
The issue- at about 3200 RPM, it intermittently jumps to around 4600 RPM and seems to lose some amount of thrust but returns to normal after reducing the RPM and increasing it again. The first time, I noticed that the motor was trimmed up a bit, so I had the driver trim it down farther, but not fully. It didn't repeat the problem until we passed through the wake from another boat and as before, it returned to normal after reducing the RPM.
We never needed to squeeze the primer bulb after I checked it before we rant it the first time, so I can't see how it would be a fuel issue, especially since the RPM increased. We took a fuel sample last Fall and at the beginning of the season- smelled normal and was clear, with no evidence of water or phase separation.
This isn't the original motor, but I was told that it never did this before. It wasn't run last year and it was used little during the previous season but judging by the condition of the spark plugs and general appearance, it was maintained fairly well. No water in the gear oil, either.
My thoughts-
Since the RPM will increase normally, I don't think it's an internal motor or gear problem. I didn't look at the prop before we went out, other than to see that it's stainless and looks to be in good condition but that doesn't mean it hasn't hit anything. That possibility leads me to my next idea- maybe it DID hit something and the hub has been damaged. I don't know the brand, but if it has a plastic insert, I have usually seen them fail to propel a boat normally, so maybe it's rubber.
Maybe the prop nut had backed off in the past and damaged the spline or the bronze washer- if it's barely digging into the spline, maybe it slips and then jams itself against good metal after the RPM reduction.
I haven't seen the model or serial numbers, so I haven't looked for a manual, yet. I should be getting this info tomorrow.
Does this sound familiar?
Thanks for any info
My thoughts-
Thanks for any info
