Dave Larson
Hello, I've read the forums and will do a pressure test next. The problem: I have an 1989 28' Carver Voyager that has rebuilt 1989 5.7L Mercruisers (gas). Unfortunately, the port rebuild has had lots of trouble so I have kind of lost track of what was fixed/replaced when. We recently had a broken head bolt which then blew a head gasket and my mechanic repaired it by taking off the head and replacing all the head bolts, gasket etc. Right before I blew the head gasket (it was immediate and I shut the engine down when it happened), I was losing a slight amount of coolant so I suspect that was because of the broken bolt and the eventual head gasket failure. So, fast forward, I get the boat back and I can run 2-5 hours at 1750 RPM, then as soon as I back down the RPM to around 750 (coming into a dock), the engine burns through coolant and overheats within 2-10 minutes. This happened 4 times in a row so it doesn't appear to be coincidence. I had to add about a gallon of coolant each time. It runs fine for 2-5 hours at 1,750 RPM and overheads and drinks coolant as soon as I drop down to 750 RPM. I thought it might be a seawater pump issue, so I had that replaced...it didn't work. There is NO coolant in the bilge. There isn't any evidence of coolant in the oil or crank case. The water pump (circulation pump) doesn't have any leaks or squeaks so that appears to be working fine. My assumption is the only place the coolant can be going is out with the exhaust with the seawater. I don't see any steam or smoke in the exhaust. Has anybody seen these symptoms before? My next step will be a pressure test on the coolant system, and I saw some sort of dye test that appears to look for exhaust in the coolant. I also saw a note about the 'elbows or riser' needing to be torqued to 20-25 pounds and if they aren't, then coolant could be going out with the seawater. If anybody can chime in, I'd appreciate it. I'm not a mechanic...just trying to learn what the problem is so I can talk coherently with .a repair shop.
