1986 Johnson 90 hp. I was having a problem with trim/tilt. I think I got that fixed, but in the process released the screw to manually raise and lower the motor.
Now the screw (inside the hole where you can see a bit of fluid coming out) won't tighten. I can't get it out, either. It is like something is attached on the back side. Red fluid comes out the hole if I raise or lower the motor.
How do I get the screw to tighten, or get it out to replace it?
