Michael1234!!!!
Motor runs good when on muffs but once I put it in water it seems to only be half throttle. 40hp only pushing boat about 12-15 mph. Give me everything to check cause it’s starting to drive me crazy
I did that. Seem to be getting good blue arc on both cylindersIt may be running on 1 cylinder, do a spark check
1985What year 40hp? ,model #?
I’ve got about 65psi on top cylinder and around 70psi on bottom cylinder. That’s way too low right?It's worth doing a compression test. I learned as a young pup working at a dealer 50 years ago. Whatever the engine came in for, you do compression, spark, and gearlube check before you ever turn a wrench on it. If you have spark ( although it should be checked at 3/8 gap on a spark checker that most people don't have). If the engine hasn't run in 10 years, it could be anything, does one spark plug look wet and the other dry?
