FlukeSkywalker
I changed my water pumps over the winter, twin f200 in-line 4’s.
when I put the port lower unit back on I have no neutral, the prop shaft spins in neutral and it clicks loud when I put in reverse like it’s goign from fwd to reverse. It stays in gear once in and doesn’t grind, just a loud click like it’s jammkng into gear.
I disconnected the shift cable and manually shifted from the engine and it still does it. I tried readjusting the spline and resetting, nothing has worked.
any idea on what is going on?
