Capri26Jeff
Hey there, The starter was not turning over the engine and by we discovered just tapping on the starter a couple times that realigned the brushes & caused the motors to start. It took some chasing but we found the right match & installed the new starter & solenoid. We felt like outlet issue was solved. But now the engine turns over, but will not fire. I must say the batteries are not turning over the engine as quick as they normally do. Could the low cranking batteries be the cause? We did not open the fuel lines, so there shouldn’t be any air on the line. Thoughts?
Tnx!
Jeff
Tnx!
Jeff
