Can you see by the carb if the upper end of the shift rod is moving when you try to shift? You probably need to drop the bottom end off the leg to check the shift cam operation. Did you drain the L/U oil...any metal fragments on the drain screw? Post the year and serial number for reference.
Thanks Guy
Year of Mariner 5 HP o/b 1997
Ser # G456033
Going to need to clear the bench to pull the bottom end and check further...
