danthemancarolina
Had a noise in my 350 mercruiser. i took the engine out and did what the manual described to fix. my camshaft is fine, lifter were fine, rods fine,piston rods fine. I took the block to a machine shop to polish (it originally got water in it from the exhaust manifold-replaced now). replace all of the rod bearings. replace the main camshaft bearing. (non looked slipped but thats what the book said).
now, it will start and idle fine. but when i add a little rpm, i get the same darn ticking noise. well its more of a really loud tapping noise. i really dont thnk that its valve lash since it was making the same sound prior to rebuild. I did not have the heads redone, maybe a valve is stuck, or maybe one of the lifters have sunk? geez this is really ticking me off...
