2003 Mercruiser 350 MAG MPI Alpha, OM362XXX, I'm guessing about 300-400 hours, in a Ebbtide 210. Engine starts without issue, hot or cold. Idles well following cold start. Runs like a top under throttle. Reducing the throttle from speed, the engine returns to idle speed with no problem. Issue presents when I then shift to neutral, engine will frequently stop. Starts right back up. I've replaced the IAC valve twice: once with an aftermarket and most recently with a Mercruiser part. New spark plugs, wires, distributor cap, PCV valve, IAC muffle; all genuine Mercruiser
Any suggestions on where to go from here before taking it to a professional who while likely take near the end of summer to get to?
