Picked up 2010 Crownline 210LS w Mercruiser 5.0 MPI SN 1A611023 a week ago. Started fine, but seemed a little rough. Initially, could not plane and get revs above 2000rpm. Seemed to clear itself out and ran fine after 15 mins. Wrote it off to old bad gas, even though I had added 1/2 tank of fresh. Tried both batteries which seem fine at 14V running. Same issue 2nd time out, so still suspecting bad gas. Burned 3/4 of the tank and filled it up with premium. Now problem seems to have gotten worse with rough start and not clearing after 20 mins. At WOT, it seems like something is cutting in/out, as it sounds like it wants to go. Seems to be running on half power. Tried pulling injector #2 plug while idling at dock and no noticeable difference in sound/revs. Same with #4 injector. Pulling #6 injector does cause it to stumble, but not stall. Seems like # 2 & 4 are not firing. Will test others tomorrow. Tried reseating the 10-pin and any other connectors easily accessible. When idling pushed down on interrupt switch and it stalled. I can see the neutral safety switch, but not sure how to test it. Haven't check distributor, rotor and plugs yet?
Any ideas appreciated.
Thanks,
Jed992
Thanks,
Jed992
