Mercury 900 90HP Dies when put in gear
T
ToddH
Guest
" I have a 1964 Mercury 900 90
" I have a 1964 Mercury 900 90HP. The motor runs great at idle, and revs up fine in neutral, and in gear, but only when it is on the garden hose. When it is in the river and the prop is submerged, whenever I go to put it in gear, the motor chugs a little bit and shuts off. Nobody around here will work on it because of its age but it is in GREAT shape ! Help me out "
" Great shape cosmetically????
" Great shape cosmetically????. Check compression, check spark on EACH sparkplug wire(must jump a gap of 5/16"). Any motor sitting for a long time can have plugged jets in the carburetors from sitting for a length of time with mixed fuel. "
I agree with Sparky. These e
I agree with Sparky. These engines have ignition problems. Make sure the spark is correct and "EACH" cylinder is firing. Good Luck.
