Hello OB277288 Mecury XR4 150. I have over heating problems thats driving me up the wall. I did a breakdown on the engine upper and lower to clear all passages, replaced gaskets and impeller. Still over heating. Replaced head gaskets as well. Compression check was 119 on all cylinders. She spits water like a champ and at high rev shoots like a garden hose. I even replace the poppet valve. Now heres the deal on the hose at home she doesnt over heat. I take her to the lake and at idle or low speed its only takes a few minutes to over heat like 8 minutes. I drove her this season like this and made due, but now shes overheating at higher rpm... I have the oem manual and read so many things it makes my head spin. I payed 3k for her year before last and hate to give up on her because of so much invested already.
She has the small gear case still btw. I replaced the prop with a new one that came with a plastic ring, the old one didnt have it. I used the ring on the prop btw. Other then that she starts every time and screems WOT, runs a lil rough at low speeds.
Any suggestion will be welcome. I cant afford to put it in the shop atm because I just spent 6k on my dogs vet bill im flat broke.
