"Motor is a E6SLD. Got some wo
"Motor is a E6SLD. Got some work to do on this..
Not knowing how good the fresh water impeller or how old I kept a close eye on the pee stream,,, Put the motor on my sailboat to try out. I asked earlier about the smoke I get both from the leg and from under the hood. Well there is quit a lot of smoke coming from under the hood and I believe there is an exhaust leak as there is more noise than maybe should be. I do have a parts catalog and in it I see what is called an "exhaust cover". Could this be a source of the smoke coming from a bad gasket? This piece has the pee hose connected to it to.
During my test run I had opened up to full throttle
to see the max power. Watching the pee stream it started to slow after I went to fast idle and by the time I got back to my dock and idling it was almost completely stopped. I then shut it down. I felt the head and spark plug area and it was very warm but not HOT so I did not over heat. Is there I web place available where I could copy and paste a chapter on impeller replacement? Has anyone tried to obtain a copy of a service manual at the Library? Thinking since I was able to replace the impeller on my 2004 5HP Nissan 4- stroke, I should be able to do the Evinrude too. This motor is a back-up for when the stupid Nissan gets it's monthly repair. (These four stroke are too sensitive to the fuel they use( it's been a Joanna for me. ) Thanks in advance for any comments here.
Chuck"
Chuck"
