Hey Everyone,
I'm a newbie and need some help on a problem with a 1994 Johnson Ocean Runner 150hp that's on my recently purchased Grady 192. The issue is that the motor will occasionally start to miss and buck at 2500 rpm. I've found through experimentation that if I restart the motor a couple of time the problem will not present itself. Recently it seems, the following procedure will "fix" the problem:
I know the motor is truly not overheating since the water pump is strong and when it does work I make long runs at high RPMS with no damage to the motor. Another interesting thing that's happening, on two occasions when the motor was running well, it went into slow mode as I trimmed it at around 4500 rpm. The motor have never done this while running at high rpm without me trimming.
Any suggestion on how to further diagnose and correct the issue would be greatly appreciated.
Thanks,
Jimmy
- WOT the motor
- Turn off the key with the motor WOT
- Put the motor in the neutral start position
- Restart
Thanks,
Jimmy
