Motor is a BF30A LHSA pre-1997.
Well, I left my brother alone for 5 minutes, and he pulled the hose out of my bucket I use to flush my motor to wash our fishing equipment... Yeah, the motor eventually sucked up enough water to put the water level below the cavitation plate, and sucked air for a good 20-30 seconds before I returned and shut the motor off. The motor was definitely much hotter than normal, and I am worried about what might have happened. I let the motor cool completely before trying to start it again, and it started fine, sounded good, and water was circulating and warming up to temp. However, I noticed that water was coming out of the exhaust, which I have never seen before. The most alarming thing, however, is that water seems to be getting into the engine oil.
Now, the rubber seal for the oil bolt on the bottom of the upper unit is slightly torn, and leaks a little oil from time to time, causing me to have to fill the engine with a little oil every now and again. But now water is dripping from the tear along with coagulated oil. So obviously water is mixing with the oil, but my question is what could cause that? Could the motor be big time damaged, or is it an easy fix? Also, what are some other things I should look out for or change because the motor overheated?
Thanks guys!
Thanks guys!
