NewBoater15
Hello there!
I just purchased a jon boat that has an outboard motor and trolling motor. The trolling motor works fine after a little bit of wiring work.
My problem here is that I have a Gamefisher 5 Outboard Motor that is having issues starting. I have done diagnostics on the motor and come to the conclusion that the Ignition Coil is not pushing out enough power to generate a spark at the .025" spark plug gap.
I'm going to be replacing the part, but I can not seem to find the model and serial number on the motor in order to purchase the correct part. Can someone tell me where I can find those numbers? Everything I'm seeing online about it is simply telling me how to depict which motor I have based on the numbers, but not where to find it!
Frustrating.
Any help would be much appreciated.
Thank you!
Thank you!
