I'm new so bear with me.
I need to know location of #1 cylinder on my 1989 4.3L.
With few exceptions (none that I know of), #1 cylinder for any engine is always the forward-most cylinder.
I also could use help with a procedure for reinstalling my distributor. I marked the housing before removing but did not mark the shaft. need procedure for installing in proper location.
Bring the crankshaft around to #1 cylinder TDC C/S (C/S = compression stroke)
It must be on the C/S.
Drop the distributor into position.
With the round cap, you'll want the rotor aiming towards the physical location of #1 cylinder. Wire the cap accordingly.
With the "crab" style cap, you'll want the rotor and cap orientated correctly regardless of aiming towards the physical location of #1.
Lightly secure the clamp so that the housing just rotates easily.
With a plug wire in #1 socket within the cap, place a good spark plug in the wire boot, and give it good contact with engine Negative.
With the ignition powered up, ** quickly rotate the distributor housing CCW until you see one spark event.
Do this several times until you get a good feel for it.
Whe this feels right, stop, and secure the clamp.
This will be close enough to fire up on.
Once BASE is set... continue checking ignition timing.
When done, tighten the clamp down so that the housing cannot rotate.
** The internal distributor shaft rotates CW.
By quickly turning the housing CCW, you'll be simulating the tiggering device turning CW.
Thanks Rick, just to be sure I understand,
1.... if #1 cylinder is at TDC just after compression,
2.... and rotor lines up with #1 spark plug wire terminal on cap, the distributor is installed correctly except for fine tune with timing setting?
