Changed the impeller and checked for flow using drill on drive shaft, good head of water, fixed onto main leg making sure water pipe fitted to pump housing, all Ok. Plenty of depth in a water butt about 4 inched below exhaust vent.....Small amount of water from exhaust upon starting then nothing. I've checked the thermostat housing without thermostat and it's quite dry except for a bit of steam. I've blown out where I can with an airline. This is a renovation project and there are signs of ' some ' overheating on the exhaust side of the engine and a ' some ' on the cylinder heads. Could there be a blockage somewhere and is it the engine off and check the usual possibilities or am I missing something ??
