timdecker30
should there be 12v at small post on solenoid with key on?i have voltage at small pos post when cranking but no voltage with just key on.ck merc switch its ok tried starting with black and yellow wire off at merc switch and switch box.no spark .the fuse on yellow wire with red stripe blew when changing battery out,but stater still cks out ok along with trigger test at swith box.Would appreciate your ideas or advie on what to do next.could the srarter solenoid cause no spark?Thank you for any help you might give
