saltlife321
"Hello. I have a 94 200 ocean
"Hello. I have a 94 200 ocean pro that will only fire one cylinder when trying to start. I dont have spark tester so I used a timing gun to check each coil wire while firing the motor. The No 2 coil is the only one firing when trying to start the motor. Some of the coils are new and I have checked the kill switches on the motor and nothing changes. I know the ignition module works cause I tested it on the starboard motor. What else can be causing this problem. The motor started fine until I used the ignition module on the starboard motor to test the motor. when I put it back in, The motor will not fire. Im getting fuel."
