No start with alarm beeper issue 1999 150 hp
howardepgco
Hi guys, I have a 1999 150 H.P XR6 engine.I went on vacation a couple of weeks ago and the motor worked great. I drove home (about 800 miles) with it on the trailer with no trouble.The next time I went to use it I could not get it to fire.I noticed after about 5 seconds of cranking the alarm starts wailing.It is a constant 2 or 3 beeps per second until I stop cranking.I checked the oil tank float with an ohm meter and it works fine.I did have an issue with the 2 psi check valve that keeps the gas from entering the under cowl oil tank.I could blow through it both ways. I changed that and bled the oil pump,but I still have the problems. This motor has the hall effect switch above the pump drive shaft.If this switch is bad does it keep the motor from starting? (safety measure?) .I can't think of why else it would be there. Any input would be greatly appreciated.
